Use Math as a Data Source
- From the Bar Chart Define panel, select .
 - Define the vector using the curve calculator to create a mathematical expression.
View new features for Altair HyperWorks 2023.1.
Learn how to manipulate plot data using the Plot Browser and other user interface tools and options.
Edit existing bar charts individually and add new bar charts to the current plot.
