Notes View
The Notes view,
                displays only the notes in the session, grouped within their respective page and
                plot folders. Click on a note to display the note's properties in the Entity Editor.
When a note is selected, the following fields are displayed in the Properties Table:
Standard
- Name
 - The name of the note.
 - Visibility
 - Displays the note in the plot window. Deactivate to hide the note.
 - Text
 - The note text or Templex expression in the note.
 - Format Scalar Values
 - Select this option to format scalar values in a note using the Fixed or Scientific format. The format type can be selected from the Format drop-down menu.
 - Format
 - Select Scientific or Fixed Format from the drop-down menu.
 - Precision
 - Both fixed decimal format and scientific notation display numbers to the right of the decimal point. The accuracy of each format can be adjusted by entering a value in the Precision text field.
 - Attach To
 - Select where the note will be attached. Options include Window, View, Curve, and Coordinates.
 - Note Placement
 - Select an option to position your note in a specific location within the
                                modeling window. The note retains its
                            position when zooming in and out. Options include:
- default
 - Left-Top corner
 - Left-Bottom corner
 - Right-Top corner
 - Right-Bottom corner
 - User defined. Use the X Coordinate and Y Coordinate fields to enter specific coordinates for the note's placement in the modeling window.
 - Options
 - See Mouse Over Notes for more information on the features in the Options section.
Display
- Font Settings
 - Click in this field to display the Font Selector dialog. From there, you can change the font type, style, and size.
 - Alignment
 - Text can be left aligned, right aligned, or centered in a note box by selecting the corresponding drop-down menu item. Text alignment is updated automatically.
 - Border Thickness
 - Determines the line thickness of the note's border. Select one of four line thickness styles from the drop-down menu to change the border.
 - Curve Color
 - This option is displayed when a note is attached to a curve.
 - Border Color
 - Click the color palette to edit the note's border color.
 - Auto Position
 - Auto Position Strategy
 - See Note Positioning for more information on this feature.
 - Background Color
 - Select default or user defined.
 - Text Color
