Use the HyperGraph Plot Browser Context Sensitive Menu
- From the menu bar, select View > Plot Browser.
                At the top level session folder, click the + button to expand the session,
                    page, and window folders.
                The curve(s) in each window(s) is displayed.
 - Select a curve and right-click on a highlighted curve to display the context sensitive menu.
                From the menu, select the option that you want to apply to the curve.
                The action is performed. If you choose a math function from the Single Curve Math or Multiple Curves Math sub-menus, a new curve is created and is added to the Session Browser and to the Curve list on the Define Curves panel.
