Values
Retrieve individual point data on any curve in the active window. When a point is selected, the point data is displayed on the panel.
See Values for more information.
View new features for Altair HyperWorks 2023.1.
Learn how to manipulate plot data using the Plot Browser and other user interface tools and options.
ON THIS PAGE
ON THIS PAGE
