Building a Car Model with an Aerodynamic System
- Starting the Assembly Wizard.
              - Start MotionView from the installation folder.The MotionView window is displayed.
- Click .
 Figure 2.The Car/Small truck - Model Type dialog opens.
- Building a Full Vehicle Model with Aerodynamic Forces
- The following steps how to make a Full vehicle model with Aerodynamic Forces.- Select the Full vehicle with driver option from the Model
                  Type dialog and click Next.
 Figure 3.
- Select the Aerodynamic Forces on the additional systems
                  page and complete the model selection.
 Figure 4.Note: Aerodynamic Forces is now included as a system.
- The Full vehicle with driver model including the aerodynamic forces system build
                  through the Assembly Wizard is displayed in the graphics area.
 Figure 5.
- The subsystems with the Aerodynamic Forces you have selected in the Assembly
                  Wizard to build the model are displayed in the browser.
 Figure 6.
Aerodynamic Forces Graphical User Interface
- Click on Aerodynamic Forces in the browser to bring up the
            Attachments section in the panel area.
 Figure 7.The corresponding panel is displayed.
 Figure 8.Attachments Description Vehicle Body *RequiredVehicle body where the action forces of Aerodynamic system is applied. Front wheel center *RequiredWheel center point pair for front axle. Rear wheel center *RequiredWheel center point pair for rear axle.
