Connections define the two connecting bodies, the point where the forces act, and the
marker that defines the bushing orientation. Bodies, markers, and points can be selected
either graphically or through the Model Browser.
From the Connectivity tab, select the first body to
connect.
The I marker of the Force_field statement in the solver
deck lies on Body 1, is located at Point 1, and has the orientation of Marker.
Similarly, select the second body to connect by
clicking the Body 2 input
collector.
The J marker of the Force_field statement in the solver
deck lies on Body, is located at Point 1, and has the orientation of
Marker.
Select a marker to orient the bushing in space.
All three axes of the bushing are along the axes of the respective axes of the
Marker (X-X,Y-Y,Z-Z).
Select a point to locate the bushing. The point defines the location where the
bushing forces act. The I marker and the J (floating) marker of the
Force_field statement are at Point 1.
Check the Output box to write
requests into the solver deck that request the force in the bushing, the
displacement across the bushing, and the relative velocity across the
bushing.
