Road Graphic Builder
The Road Graphics Builder creates a graphic representation of a road description file which you can use to visualize the road surface in MotionSolve and HyperView.
The Road Graphics Builder supports the following commonly used road description files:
Curved Regular Grid (CRG)
Regular Grid Road (RGR)
- xmin, ymin: the grids minimum value in x- and y- directions respectively.
- ∆x, ∆y: the grids constant mesh size in x- and y- directions respectively.
- nx, ny: the number of grid nodes in x- and y- directions respectively.
3D Spline Road
