Percentage Thickness Calculation for Shells
In HyperView, the existing implementation of thickness calculation is based on strain data available with result file. In the case where the strain data is not available in the results, HyperView is not able to show the percentage change in the thickness. The existing method of calculating the percentage change in thickness using strain is the most generic method and takes away any assumptions on the initial sheet thickness. However in absence of strain data in the result file, HyperView needs to be able to calculate the percentage thickness reduction based on the thickness at the time step 0. The implementation to meet this need is explained below.
Radioss Implementation
- % thickness reduction result type available from result.
- % thickness reduction calculation from strain results.
- % thickness reduction calculation from thickness.
- Case 1
- The result type is available in HyperView upon reading and a contour plot can be applied as it is currently.
- Case 2
- HyperView calculates from a) current thickness and b)
current strain at every time step. Depending upon the user request, several options
for strain are available. Only the strains with following data names can be used for
calculation of thickness:
- Strain tensor and layer: Membrane
- Strain tensor and layer: Upper and Lower
In case of data name strain, membrane, the calculation for each step as follows:
Loop through the following for very element
Read the current step thickness for an element: Thicknesscurrent
Read the strain tensor for an element this is usually in global coordinate system
Map it to the shell elements coordinate system
Get the strain along the element normal (Ezz)
Get the thicknessinitial = Thicknesscurrent /exp(Ezz)
In case of data name strain, upper, and lower the calculation for each step as follows:
Read the strain upper and lower tensor for an element
Calculate the membrane strain components = (Strain upper + Strain lower)/2. These are in global coordinates.
- Case 3
- HyperView assumes that initial thickness is the
thickness at time step zero. Therefore, the calculation needs to be done as
follows:
Time step =0
Get the element thickness Thicknessinitial
For all time steps
Loop through the following for every element
