Boolean On Sets
Use the Boolean Operations tool to list elements and create new sets.
From the menu bar, click .
- Union
- Intersection
- Union-Intersection
- Remove list B from list A
- Remove list A from list B
View new features for Altair HyperWorks 2023.1.
Create an assembly structure from a .csv file definition.
Use the Quick Set tool to create relevant elements that are masked to ease further selection/generation.
Select either elements or nodes from the model and find the sets that are collected.
ON THIS PAGE
From the menu bar, click Aerospace > Sets > Boolean On Sets.
ON THIS PAGE
