FE Absorb Plies
FE Absorb Plies generates a ply-based model from zone-based properties.
View new features for Altair HyperWorks 2023.1.
Pre-processing in HyperMesh.
An introduction to composites terminology and modeling methods.
Examples of a typical workflow that can be followed to define a composite model in HyperMesh. The order of steps provided does not need to be strictly followed but should be used as a template.
Use the Composite Browser to create, organize, and manage composite modeling data.
Entities that comprise composite parts.
Utilities for working with composite models.
Aerospace tools for working with composites.
Supported CAD readers and writers for CATIA and FiberSim.
Kinematic Drape provides methods to predict manufacturability of composite parts with challenging shapes and to align material direction for the structural simulation. Draping simulation predicts how the orientation of a ply will change as the ply is placed in a tool/mold.
The Material Reference Orientation tool provides several tabs to set and review x and z material reference orientations.
Ply Geometry Smoothing provides functionality to smooth finite element ply shapes, usually generated from concept level composite freesize optimization, and to generate geometry from finite element ply shapes.
Ply Rename provides several automated ply renaming methods
Visualization of thickness, layers, and orientations.
Use the Injection Molding ribbon to facilitate the development of accurate structural simulation models for reinforced injection molded parts and assemblies.
Composite stress toolbox functionality which supports calculation of engineering constants, compliance and stiffness matrices, parameterized joint and panel analysis, and other traditional hand-calculation methods.
Development of multiscale and single scale material models and simulation of parts manufactured from any heterogeneous and homogenous material.
