Plot RBE/MPC
Use the Plot RBE/MPC tool to plot RBE and MPC considering a RBE3/MPC with a given weighting factor where the nodes are written in a certain displacement coordinate system.
From the menu bar, click .
View new features for Altair HyperWorks 2023.1.
Create an assembly structure from a .csv file definition.
Use the Orientation Review tool to display/review and modify frequently used coordinate systems used in CAE analysis.
In the modeling window, display mass, center of gravity, or moment of inertia as markers.
Use the Dataname Viewer tool to display either scalar or new marker plots on elements/nodes associated to their data names and attributes. For elements the link can be extended directly to the associated properties and materials.
Use the Control IDs from Selection tool to create a list of selected nodes/elements, review and control IDs.
ON THIS PAGE
From the menu bar, click Aerospace > Display > Plot RBE/MPC.
ON THIS PAGE
