Create Link Attachments to Connectors
Create new connectors from attachments or from existing collectors.
                From the Connectors ribbon, click the Connect
                        Attachments tool.
Figure 1. -
                Click
 on the guide bar.
                Choose an option in the Selection tab.
- From Attachments - After you create and define attachments, you can create connectors using a tolerance search.
 - From Existing Connectors - Convert existing connectors into attachment links.
                Choose a detection method in the Link Detection tab.
                Connectors and attachments can be selected automatically or manually.
For attachments, you must enter a tolerance and angle value. The tolerance search will look normal to the hole (within 100) of the created attachment to find other attachments.
 - If link detection is set to Manual, use the selector on the guide bar to choose attachments or connectors.
                If creating connectors from attachments, use the drop-down menu to assign an
                    attachment control to the connector.
                Choose a previously defined control or click Create New to open the Control Manager and define a new control. If you select Undefined, the connector will be created without a control.
By default, an assigned control is realized.
                On the guide bar, click one of the following:
 - Apply and stay in the tool
 - Apply and close the tool
 - Exit the tool without applying
