Create and Edit Arc Lines
Use the Arc Lines tool to create arcs for geometry construction, edit free arcs, and create/toggle filled arcs.
New arcs are organized in the same component as the entity where the center point is placed.
When there is ambiguity, the Arc Lines tool switches between possible inferred normals.
 to translate and rotate the
                        arc using the
                        arc using the  to imprint lines.
 to imprint lines.
