Inspire Writer
Supported Entities
- Model
- Assembly
- Part
- Solid
- Sheet
- Curve
- Point
- Axis System
- Facets/Triangles
- FE Models
Export Option
@AssemblyMode
Value | Description |
Parts |
Create part entity hierarchy as assembly and part entity in Inspire. |
Assemblies |
Create assembly and component entity as assembly and part entity in Inspire. |
Flatten |
Write entities in all components into a single Inspire part. |
@Export
All |
Export all geometry (default). |
Displayed |
Export displayed geometry only. |
@ExportFEModels
on |
Export FE models (default). |
off |
Do not export FE models. |
@GeometryMode
Standard |
Write CAD geometry with standard types such as cylinder, cone, circle, and so on (default). |
BSpline |
Convert all surface geometry data into NURBS. This option may increase the output file size and be time consuming depending on the actual geometry. |
@NameFromRepresentation
on |
Assign part name in CAD file from the representation file
name attached to part entity. Meaningful only if
off |
Assign part name in CAD file from the part entity name in the
application. Meaningful only if |
@OptimizeForCAD
on |
Fix gaps between stitched edges and vertices to make the actual geometry of the surfaces consistent with the model topology before export, and check the topology of the model for gaps that are larger than a given tolerance between shared, non-manifold, or suppressed edges. If the gap is found to be bigger than the tolerance, the surface and edge geometries are morphed parametrically and in 3D, if necessary, to make the gap smaller than the tolerance. In addition, non-essential degenerate edges are removed. This also modifies the geometry within the application (default). |
off |
Do not perform the optimization steps. |
@SourceUnits
Unit system assigned to the data present in the application during export |
@TargetUnits
Units system in the Inspire file. |
@TopologyMode
Solid/Shell |
Export topology data similar to the application's topology data, keeping the distinction between solids and shells (default). |
Surface |
Export each surface, including solid faces, as a single surface, effectively neglecting connectivity. |
@Version
string |
Inspire version to use for export. Valid versions are 2018.1 (default), 2017.1 |
