Use the Extend Lines tool to make an existing line longer, following the general
vector and/or curvature of the input line. You can specify the distance as a numeric value,
or extend the line to a specified node, line, surface, or point.
Note: This is not applicable for FE geometry. The
selectors and operation are strictly for CAD lines.
From the Topology ribbon, Lines tool group, click the Combine/Extend Lines tool.
Select Extend from the guide bar
drop-down.
Select lines to extend.
Extend in the following ways:
On the guide bar, click one of the following:
