Create and Edit Points/Nodes
Use the Create Points/Nodes tool to create and edit points/free nodes on geometry surfaces and lines or in space.
New points created on existing geometry are organized in the same component as the source geometry, and new points created in empty space are organized in the current component.
- Create points and nodes at predefined points on geometry, such as end, middle, center, and intersection points. When interpolating points and nodes, you can also snap to points along the x, y, and z axis.
- Copying and pasting topology vertices (fixed points) generates free points and organizes them in the same component.
 to enter coordinates with respect to a local
                        coordinate system.
                        coordinate system. on the
 on the
