Extrude Geometry
Extrude surfaces, nodes, or lines along their normal direction, a vector, or another line.
A extrude preview for FE geometry solids is not supported at this time.
Auto-Trim
Use the auto-trim  option in the microdialog when extruding nodes and lines.
While extruding lines or nodes, if a continuous surface or mesh is intersected and this option is ON, the newly created surfaces are trimmed at the intersection. The auto-trim option works for both geometry intersecting geometry and mesh. It also works for FE topology intersecting FE topology.
 Figure 2. Surfaces intersecting with surfaces
                Figure 2. Surfaces intersecting with surfaces Figure 3. Surfaces intersecting with mesh
Figure 4.
Figure 5.
 ) that allows you to stitch trimmed surfaces to the
                target surfaces. Note that option is only applicable if auto-trim is turned
                    ON.
                    ON.|  Figure 6. Input lines |  Figure 7. Stitch trimmed surfaces ON |  Figure 8. Stitch trimmed surfaces OFF |
 to define additional options.
                    to define additional options. to define a direction using the
 to define a direction using the  - Apply and stay in the tool
 - Apply and stay in the tool - Apply and close the tool
 - Apply and close the tool - Exit the tool without applying
