The Generate PSM for MADYMO function allows you to save analysis results of nodes as
        a PSM (Prescribed Structural Motion) file. Displacement results from any animation can be
        exported as a PSM file.
            To generate PSM for MADYMO:
                From the Utilities Menu, select Generate PSM for
                    MADYMO....
                The Node selection panel is displayed.
                Click the Nodes button and graphically select the nodes to export.
                Click Apply.
                In the Madymo PSM dialog that appears, click
                        Yes to convert the displacement by dividing
                    1000.0.
                        Yes to convert the time units by dividing
                    1000.0.
                From the Specify a Name for the PSM File dialog, select
                    the directory and name to which you want to save your file.
                Click Save.
                Click OK.
