| Temperature | NODE | SCALAR |
                | Strain Energy Density | NODE | SCALAR |
                | Equivalent Stress | NODE | SCALAR |
                | Hydrostatic Stress (equivalent pressure stress) | NODE | SCALAR |
                | Volumetric strain | NODE | SCALAR |
                | Principal Stresses (Maximum, Middle and Minimum) | NODE | SCALAR |
                | Principal Strains (Maximum, Middle and Minimum) | NODE | SCALAR |
                | Principal elastic strains (Maximum, Middle and Minimum) | NODE | SCALAR |
                | Equivalent Elastic Strain | NODE | SCALAR |
                | Volumetric Elastic strain | NODE | SCALAR |
                | Volumetric thermal strain | NODE | SCALAR |
                | Principal thermal strains (Maximum, Middle and Minimum) | NODE | SCALAR |
                | Equivalent plastic strain | NODE | SCALAR |
                | Yield stress | NODE | SCALAR |
                | Volumetric plastic strain | NODE | SCALAR |
                | Plastic strain magnitude | NODE | SCALAR |
                | Principal plastic strains (Maximum, Middle and Minimum) | NODE | SCALAR |
                | Average, Amplitude, Maximum of strain energy density | NODE | SCALAR |
                | Equivalent creep strain | NODE | SCALAR |
                | Principal creep strains (Maximum, Middle and Minimum) | NODE | SCALAR |
                | Displacement | NODE | VECTOR |
                | Rotation | NODE | VECTOR |
                | Reaction force | NODE | VECTOR |
                | Velocity | NODE | VECTOR |
                | Angular Velocity | NODE | VECTOR |
                | Acceleration | NODE | VECTOR |
                | Angular acceleration | NODE | VECTOR |
                | Eigen vectors of Principal stresses | NODE | VECTOR |
                | Eigen vectors of Principal strains | NODE | VECTOR |
                | Eigen vectors of principal elastic strains | NODE | VECTOR |
                | Eigen vectors of principal thermal strains | NODE | VECTOR |
                | Eigen vectors of principal plastic strains | NODE | VECTOR |
                | Eigen vectors of principal creep strains | NODE | VECTOR |
                | Heat flux vector | NODE | VECTOR |
                | Temperature gradient vector | NODE | VECTOR |
                | Negative temperature gradient vector | NODE | VECTOR |
                | Contact Normal vector | NODE | VECTOR |
                | Contact displacement | NODE | VECTOR |
                | Contact Traction | NODE | VECTOR |
                | Stress tensor | NODE | TENSOR |
                | Strain tensor | NODE | TENSOR |
                | Elastic Strain Tensor | NODE | TENSOR |
                | Thermal strain tensor | NODE | TENSOR |
                | Plastic strain tensor | NODE | TENSOR |
                | Creep strain tensor | NODE | TENSOR |
                | Strain Energy Density | ELEMENT | SCALAR |
                | Equivalent Stress | ELEMENT | SCALAR |
                | Hydrostatic Stress | ELEMENT | SCALAR |
                | Volumetric Strain | ELEMENT | SCALAR |
                | Principal Stresses (Maximum, Middle and Minimum) | ELEMENT | SCALAR |
                | Principal Strains (Maximum, Middle and Minimum) | ELEMENT | SCALAR |
                | Equivalent Elastic Strain | ELEMENT | SCALAR |
                | Volumetric Elastic Strain | ELEMENT | SCALAR |
                | Principal elastic strains (Maximum, Middle and Minimum) | ELEMENT | SCALAR |
                | Volumetric thermal strain | ELEMENT | SCALAR |
                | Principal thermal strains (Maximum, Middle and Minimum) | ELEMENT | SCALAR |
                | Equivalent plastic strain | ELEMENT | SCALAR |
                | Yield stress | ELEMENT | SCALAR |
                | Volumetric plastic strain | ELEMENT | SCALAR |
                | Plastic strain magnitude | ELEMENT | SCALAR |
                | Principal plastic strains (Maximum, Middle and Minimum) | ELEMENT | SCALAR |
                | Average, Amplitude, Maximum of strain energy density | ELEMENT | SCALAR |
                | Equivalent creep strain | ELEMENT | SCALAR |
                | Principal creep strains (Maximum, Middle and Minimum) | ELEMENT | SCALAR |
                | Yield region | ELEMENT | SCALAR |
                | Eigen vectors of Principal stresses | ELEMENT | VECTOR |
                | Eigen vectors of Principal strains | ELEMENT | VECTOR |
                | Eigen vectors of principal elastic strains | ELEMENT | VECTOR |
                | Eigen vectors of principal thermal strains | ELEMENT | VECTOR |
                | Eigen vectors of principal plastic strains | ELEMENT | VECTOR |
                | Eigen vectors of principal creep strains | ELEMENT | VECTOR |
                | Heat flux vector | ELEMENT | VECTOR |
                | Temperature gradient vector | ELEMENT | VECTOR |
                | Negative temperature gradient vector | ELEMENT | VECTOR |
                | Stress tensor | ELEMENT | TENSOR |
                | Strain tensor | ELEMENT | TENSOR |
                | Elastic Strain Tensor | ELEMENT | TENSOR |
                | Thermal strain tensor | ELEMENT | TENSOR |
                | Plastic strain tensor | ELEMENT | TENSOR |
                | Creep strain tensor | ELEMENT | TENSOR |
