Manage Extensions
Use the Extension Manager to register, view currently registered, and load/unload/remove extensions.
View new features for Altair HyperWorks 2023.1.
Learn how to start applications on Windows and Linux.
HyperMesh Batch is a non-graphical version of HyperMesh that can be used to run command files or Tcl scripts in batch mode.
The start-in directory is the location from which the application is launched.
Settings files include command<#>.tcl and hwsettings.xml.
There are various types of startup customizations that are possible. These items define how the application looks or behaves at product startup.
HyperMesh allows you to create a script file named hmcustom.tcl that can be used to automatically execute a series of commands or to define custom settings during startup.
Environment variables can be defined to configure various aspects of the application.
Format of customized extension.xml files.
Format of customized ribbon page .xml files.
Format of customized toolbar .xml files.
Format of customized filemenu.xml files.
HyperMesh has a configuration file named hm.cfg, which is read on startup and is located in the <install_directory>/hw/bin/<platform> directory.
A preference file is an ASCII file that configures the application or its clients. It specifies default user settings, such as the order in which colors are assigned, the default printer and default page layout.
A session file is an ASCII text file that contains a structured list of session statements.
Report templates are ASCII text files that contain statements for creating reports.
<entry name="removable" value="true"/>© 2023 Altair Engineering, Inc. All Rights Reserved.
