Import and Export CSV Files
You can import and export comma separated value files (CSV) to and from TableView. There are two ways to access this feature:
Or
View new features for Altair HyperWorks 2023.1.
Load an Excel CSV file into TableView.
Display the data contained in the selected TableView cell.
Displays the data contained in the currently selected TableView cell.
Overlay reports for summary tables.
Show or hide the table column headers and row numbers.
Refresh the table data.
TableView supports cell math references in a Templex expression, like the support of curve math references in HyperGraph.
From TableView, use the Table Browser to view the current session and all pages and windows it contains in a hierarchical display.
From within a cell, row number, or column header in TableView, right-click to display the following context menu items.
ON THIS PAGE
Or
ON THIS PAGE
