Configure Browsers
Change the display and behavior of browsers.
Note: Not all browsers can be configured.
                To edit options specific to a browser and a solver
                    interface:
                - Right-click in a browser and select Configure Browser from the context menu.
- Edit any local options.
- If available, use the Entities tab to select the entity types that are displayed in the browser.
 Note: To configure global browser options that are common across all interfaces, go to File > Preferences > Browsers.
                To change the columns/attributes that display in a browser, right-click on a column heading and toggle
                    checkboxes in the microdialog.
 Figure 1. Attribute Configuration Options for the Model Browser
