In this tutorial, you will learn how to create a pendulum model using Model Definition Language (MDL), run a dynamic
simulation of the model, plot the rotation of the pendulum and view the animation.
In this tutorial, you will learn to create a dataset to specify the start time, mid time, end time, and the force
magnitude, include dataset definition in the analysis definition, and vary the magnitude and time of the impulse torque.
In this tutorial you will learn how to create systems using the MotionView graphic user interface, export a system definition to a file, and instantiate a saved definition in a model.
This manual provides a detailed list and usage information regarding command statements, model statements, functions and
the Subroutine Interface available in MotionSolve.
MV-1060: Build a Pendulum Model Using MDL Statements
In this tutorial, you will learn how to create a pendulum model using Model Definition Language (MDL), run a dynamic simulation of the model, plot the rotation of the pendulum and view the animation.
MV-1090: Creating a Dataset Using MDL
In this tutorial, you will learn to create a dataset to specify the start time, mid time, end time, and the force magnitude, include dataset definition in the analysis definition, and vary the magnitude and time of the impulse torque.
MV-1030: Create a System Definition Using the MotionView GUI
