KDYN
I/O Options and Subcase Information Entry The KDYN command can be used in the I/O Options or Subcase Information sections to request dynamic stiffness output for all subcases or individual subcases respectively.
KDYN(sorting,format,form,rotations) = option
Argument | Options | Description |
sorting | <SORT1, SORT2, blank> Default = blank |
This argument only applies to the PUNCH format (.pch file) output for Frequency Response subcases. It is without warning if used elsewhere.
format | <H3D, PUNCH, blank> Default = blank |
form | <REAL,
PHASE, blank> Default = REAL |
rotations | <ROTA,
NOROTA> Default = NOROTA |
option | <YES,
ALL, NO,
NONE, SID> Default = ALL |
- When the KDYN command is not present, dynamic stiffness is not output.
- Dynamic stiffness is calculated as the reciprocal of displacement.
- KDYN output request is only supported for Frequency Response analysis.
- Results in binary format (.h3d) are always output in PHASE/MAG form, regardless of the options specified in the FORM field. The corresponding post-processors (HyperView/HyperGraph) can easily convert the PHASE/MAG format to the required formats. Results in ASCII formats are output in the specified/requested FORM.
