/ANIM/SHELL/EPSP
Engine Keyword Generates animation files containing plastic strain as function of a shell element integration point.
/ANIM/SHELL/EPSP/Keyword4/Keyword5
Definition
| Keyword4 | Integration point
                                location for all properties except composites. Layer location when
                                composite properties are used. 1
                                2
| Keyword5 | Integration point
                                location. Only used for composite properties,
                                    /PROP/TYPE51, or /PCOMPP.
                                    3
                                4
- For composite properties, layer numbers start at 1 and increase numerically in the order defined in /PROP/TYPE9 (SH_ORTH), /PROP/TYPE10 (SH_COMP), /PROP/ TYPE11 (SH_SANDW), /PROP/TYPE16 (SH_FABR), /PROP/TYPE17 (STACK), /PROP/TYPE51, or /PCOMPP.
 - For fully integrated BATOZ shells, Ishell=12, the output value is the average of the in-plane Gauss points.
 - For
                        /PROP/TYPE51 or /PCOMPP composite
                    properties, if Keyword5 is not defined.
If Keyword4=ALL, the result is output for all layers and the value per layer is the average value of the through thickness integration points in the layer.
If Keyword4=LOWER, the result is the value of the first integration point of the first layer.
If Keyword4=UPPER, the result is the value of the last integration point of the last layer.
 - Keyword5
                        limitations:
It can only be used with /PROP/TYPE51 or /PCOMPP composite properties and only if Keyword4=N, the layer number. However, Keyword4=ALL can be combined with Keyword5=ALL to output all layers and all integration points. If Keyword5=ALL, results for 10 integration points will be output, even if less integration points were defined in each layer and thus some results will be zero.
