LS-DYNA Input Interface KeywordThis keyword should always be the first card of the input file. Optionally used with *CONTROL_UNIT card to specify model units.
*DATABASE LS-DYNA Input Interface KeywordDefines the output frequency for time history data.
*DATABASE_BINARY_D3DUMP LS-DYNA Input Interface KeywordDefines the output frequency for the writing of restart files.
*DATABASE_BINARY_D3PLOT LS-DYNA Input Interface KeywordDefines the output frequency for animation files.
*DATABASE_BINARY_INTFOR LS-DYNA Input Interface KeywordDefine the contact force and pressure vector and the output frequency for animation files.
*DATABASE_BINARY_RUNRSF LS-DYNA Input Interface KeywordDefines the output frequency for the writing of restart files.
*DATABASE_CROSS_SECTION_PLANE LS-DYNA Input Interface KeywordDefine a cross plane section to output the force and moment defined by part set.
*DATABASE_CROSS_SECTION_SET LS-DYNA Input Interface KeywordDefine a cross section to output the force and moment defined by a group of nodes and groups of elements.
*DATABASE_EXTENT_BINARY LS-DYNA Input Interface KeywordDefine the results written in the animation output files.
*DATABASE_HISTORY LS-DYNA Input Interface KeywordThis keyword defines which entities are output to the time history file.
*DATABASE_HISTORY_NODE LS-DYNA Input Interface KeywordDefines a list of nodes for output in time history file.
