Global User Window
With Radioss, it is possible to define a global user window. This is the most general interface between Radioss and external code.
- The Starter subroutine is called
USERWISand is used to read the global data and to initialize global memory. - The Engine subroutine is called
USERWIand is used to compute the forces and moments.
