Engine Keyword In this group keywords are used to generally define the output style, control of computation, damping and ALE setup
during the computation.
Generates animation files containing results according to the keywords specified. The keywords are specified in the
topics within Animation and Post-processing Output Files.
Engine Keyword In this group keywords are used for implicit solution. Different implicit solver methods (linear, nonlinear, buckling
or quasi-static), different options to control the implicit computation, different implicit time step method and
implicit output messages are introduced.
Engine Keyword The full projection of QEPH shell element for warped elements will be deactivated to keep consistency between the
stiffness matrix and the internal force computations.
Engine Keyword The full projection of QEPH shell element for warped elements will be activated for stiffness matrix to keep consistency
with the internal force computations.
Engine Keyword In this group, keywords are used to define the kinematic condition (constrain/release rotation or translation DOF)
and initial condition (rotational/translational velocity).
Engine Keyword In this group, keywords are used to define different time step control (STOP, KILL, CST or DEL, and so on) for different entities (shell, brick, beam, airbag, interface, and so on) during the computation.
Engine Keyword In this group, keywords are used to output different info (like stress, strain, orthotropy direction, temperature,
and so on) in a state file (STA-File).
/IMPL/RREF/INTERF/n Engine Keyword Different reference force residual computations used for stop criteria on nonlinear analysis with contact.
/IMPL/RREF/LIMIT Engine Keyword Define reference force residual limit values used in stop criteria for implicit nonlinear.
/IMPL/RREF/OFF Engine Keyword Deactivation reference residual option and using the previous one in stop criteria for implicit nonlinear analysis.
/IMPL/SBCS/MSGLV Engine Keyword Describes the message level for BCS (Boeing) solver.
/IMPL/SBCS/ORDER Engine Keyword Reordering method definition for BCS.
/IMPL/SBCS/OUTCORE Engine Keyword BCS solver will use minimum in-core memory.
/IMPL/SHPOFF Engine Keyword The full projection of QEPH shell element for warped elements will be deactivated to keep consistency between the stiffness matrix and the internal force computations.
/IMPL/SHPON Engine Keyword The full projection of QEPH shell element for warped elements will be activated for stiffness matrix to keep consistency with the internal force computations.
/IMPL/SINIT Engine Keyword Describes the initial stresses that will be imposed gradually.
/IMPL/SPRBACK Engine Keyword Implicit spring-back will be run in this session.
/IMPL/SPRING Engine Keyword Describes the linear or nonlinear stiffness choices for nonlinear spring in implicit nonlinear analysis.
