#RADIOSS STARTER
Block Format Keyword Mandatory header keyword for the Starter Input file (Runname_0000.rad). This MUST be the first keyword in a Radioss Starter Input.
- After the header, comment lines may be inserted. Command lines must begin with $ or #.
- The run identification name is input using the keyword /BEGIN.
