Monitored Volume
An airbag is defined as a monitored volume. A monitored volume is defined as having one or more 3 or 4 node shell property sets.
Figure 1. Tire Model: Volume Closed
- AREA Type: volume and surface output (post processing option, no pressure)
 - PRES Type: user function defining pressure versus relative volume
 - GAS Type: adiabatic pressure volume relation. with
 - AIRBAG Type: Single airbag
 - COMMU1 Type: Chambered, communicating, folded airbag (airbag with communications)
Same basic equations:
- For tire use PRES or GAS type monitored volume.
 - For fuel tank use PRES or GAS type monitored volume.
 - For simple unfolded airbag use AIRBAG type monitored volume.
 - For chambered airbag use two ore more COMMU1 type monitored volumes.
 - For folded airbag use a set of COMMU1 type monitored volumes.
