The stability conditions of explicit scheme in SPH formulation can be written over cells
  or on nodes.
Cell Time Step
In case of cell stability computation (when no nodal time step is used), the stable time step is
    computed as:
(1)
      is the user-defined coefficient (Radioss option /DT or /DT/SPHCEL). The value of
     =0.3 is recommended. 1
Nodal Time Step
In case
    of nodal time step, stability time step is computed in a more robust way:
(2)
        at particle
Use the following notations, if kernel correction:
(3)
Or, if no kernel correction:
(4)
Recalling that apart from the artificial viscosity
     terms:
(5)
write
(6)
Where,
      is the relative displacement of particles
      and
     . Keeping the only first order terms leads to:
(7)
Where,
(8)
that is
(9)
Same reasoning leads to:
(10)
So that
(11)
Stiffness around node
      is then estimated as:
(12)
