Optimization will find the most effecitve design for each design space in a model in response to the applied loading
conditions on that model. You can run several different types of optimization including topology, topography,gauge,
and PolyNURBS shape optimization.
Evaluate designs by using geometric variables and applying a design-of-experiments (DOE) or optimization method. We
recommend fully constraining your sketch when sketch variables are used in the design exploration.
Click the Run group label to define how jobs are run.
Figure 1. Run Options Menu
Note:
The option to Add a Server is available for structures and the SLM process in
print3D, but not for motion, binder-sinter, porosity, or thinning analyses. The
Manual Remote option is only available for structures analysis.
Local Sequential
Queue run requests on your local computer and run one after the other.
Local Parallel
Immediately execute all runs simultaneously on your local computer.
Manual Remote (Structures only)
Manually run a job on a remote server. Select this option if using a remote
server that is not an Altair PBS server.
Custom Server
If you have added a remote server, the name of the server will appear in the
menu. Select it to run jobs remotely on that server.
Add Server
Add and configure a remote job server.
Note:For more information about how to install and configure a
remote job server, refer to the Inspire Remote Job Submission
Guide, available on the Altair Help Center.
