Connector for Elasticsearch 6.x
The Elasticsearch 6.x connector allows you to connect and access data from an Elasticsearch cluster using Transport Client.
    NOTE  |
    · To enable the Elasticsearch 6.x connector, refer to Elasticsearch Connectors Dependency Installation for more information on how to copy the provided dependency files to the Lib folder. · The Elasticsearch 6.x connector supports Elasticsearch 6.x versions. · Elasticsearch 6.x and Elasticsearch 7.x connectors will not work in a single Panopticon Real Time instance due to conflicting Elasticsearch API dependencies.  |
1. Enter the following information:
    Property  |
    Description  |
    Host  |
    The hostname of any node in your Elasticsearch cluster, or localhost for a node on your local machine.  |
    Port  |
    The port running the Elasticsearch HTTP service (default is 9300). If the port you wish to use is different from the default port, change the value to the correct one.  |
    Cluster Name  |
    The cluster name that can be used to discover and auto-join nodes.  |
    Index Name  |
    The Index name in Elasticsearch. This is some type of data organization mechanism that allows partition of data in a certain way.  |
2. Enter an optional JSON-encoded request body in the Query box.
