Connector for Elasticsearch 7.x
The Elasticsearch 7.x connector allows you to connect and access data from an Elasticsearch cluster using Java High Level REST Client.
    NOTE  |
    · To enable the Elasticsearch 7.x connector, refer to Elasticsearch Connectors Dependency Installation for more information on how to copy the provided dependency files to the Lib folder. · The Elasticsearch 7.x connector supports Elasticsearch 7.x versions. · Elasticsearch 6.x and Elasticsearch 7.x connectors will not work in a single Panopticon Real Time instance due to conflicting Elasticsearch API dependencies.  |
1. Enter the following information:
    Property  |
    Description  |
    Host  |
    The hostname of any node in your Elasticsearch cluster, or localhost for a node on your local machine.  |
    Port  |
    The port running the Elasticsearch HTTP service (default is 9300). If the port you wish to use is different from the default port, change the value to the correct one.  |
    User Id  |
    The username used to connect to the Elasticsearch 7.x service.  |
    Password  |
    The password used to connect to the Elasticsearch 7.x service. Check the Show Characters box to display the entered password characters.  |
    Cluster Name  |
    The cluster name that can be used to discover and auto-join nodes.  |
    Index Name  |
    The Index name in Elasticsearch. This is some type of data organization mechanism that allows partition of data in a certain way.  |
2. Enter an optional JSON-encoded request body in the Query box.
3.     Click
. The
	 columns populate the Output Column section.
4.     Click
 to add columns and specify their properties:
    Property  |
    Description  |
    Name  |
    The column name of the source schema.  |
    Type  |
    The data type of the column. Can be a Text, Numeric, or Time  |
    Date Format  |
    The format when the data type is Time.  |
    Enabled  |
    Determines whether the message field should be processed.  |
To delete a column,
	 check its
 or
	 all the column entries, check the topmost
, then click .
