| Column |
- Not Define
- Define
You can define the column to list in the working area. Also,
you can show the selected item in Define Column. |
| Type |
- Ref. Type
- Part Type
- Stock ID Type
When displaying Working Area, you can decide how to list
item(s) by default. The above figure is based on the reference
type. |
| Reference Placement Layer |
- TOP
- BOTTOM
| Excel Import |
- Apply EBI file as Default
- Excel BOM Information(EBI) File Path
As items related to Excel Format Setting, this extension is
*.EBI. In order to use PollEx CP, you need to change the format of
interfaced BOM data. In the Setting window, if you set the path of
the *.ebi file, you do not need to set it every time. For more
information about Excel Format Setup, refer to the Excel Format
Setup. |
| Language |
- Menu(dialog)
- Manual
