Case 2: BGA Type
- In the Footprint Configuration Table Editor, click Add.
For Package Code, select BG.
Figure 1. - Pin Type: Display the pin type of configuration table.
- Usage Code: Select the usage code for configuration table.
- Pin Pad Size Input Type: Select the method for defining pad size among Size Dimension and margin from Drill Hole.
- Note: Input comment about configuration table.
- Padstack Information: Define the shape and size of the padstack.
