Connected Multi Comp
Rule check for special purpose filters that consist of several components.
- Item: Input item name.
- Multi Num:
Select a target component group. When an empty raw is double clicked, the
Multi Comp Group setting window will be displayed.
Figure 2.- Connected Comp Num: Define the number of filter component.
- Upon clicking, required number of component list will be displayed in List field.
- Click each item, then Select Group dialog will be displayed.
- Select Component Group then click OK.
- Multi Comp: Display selected comp group name defined at stage Multi Num.
- Net: Define required net group to which the filter circuit should be connected.
- Except Net: Define net group to be excluded.
- Standard Net: Enter a string to choose specific net from all nets.
