Pin Mapping Setup
To generate composite-nets, the composite component and pin-mapping information are needed.
Figure 1. Array Component Pin Paring
- To define the Component Group, click the first ... icon.
In the Select Group dialog, select the component groups
which have multi-pin components.
- Click OK.
- To define the Property, click the second ... icon.
In the Select Component Property dialog, select the
property that describes the pin pairing information.
- Click OK.
