Solve an analysis or design study.
                Solve an individual analysis.
                        In the Project Tree, select the analysis to
                            open the Analysis Workbench.
                        On the workbench toolbar, click
 (Solve).
                        The Analysis Workbench opens. A progress
                            bar appears in the application window to update you on the progress of
                            the analysis. Once the run is complete, a Results branch appears in the
                                Project Tree.
                Solve a design study/multiple analyses.
                        In the Project Tree, select the design study or
                            project name to open the Analysis Workbench.
 (Solve).
                        The solver manager opens.
                        In the Solver Manager, select the check boxes
                            for the analyses or design studies you want to solve.
                        Click Solve.
A progress bar appears in the application window to update you
                            on the progress of each analysis. Once each analysis is complete,
                            Results branches appear in the Project Tree that
                            you can view after all analyses are complete.
