Altair EDEM
Use loads from Altair EDEM in SimSolid analysis.
Export Loads
Import to SimSolid
Import loads from Altair EDEM.
- Launch SimSolid.
 - To analyze the loads, on the Project Tree, select the same geometry specified in the Geometry field of the EDEM export window.
                Apply EDEM-generated loads.
                        Create a structural analysis
                     - On the Analysis Workbench toolbar, select .
 - In the window, click Import from CSV.
 - Select the .csv file generated by EDEM.
 - Click OK.
 - Apply other boundary conditions and model settings.
 - Run the analysis.
