List of keyboard shortcuts available in SimSolid.
        File Management
                                | Shortcut |
                                Function |
                                | Control + I |
                                Import CAD file |
                                | Control + O |
                                Open project |
                                | Control + S |
                                Save project |
                                | Control + W |
                                Close project |
                                | Control + Q |
                                Quit SimSolid |
        Display
                            | Shortcut |
                            Function |
                            | H |
                            Hide selected parts  |
                            | I |
                            Isolate selected parts |
                            | S |
                            Suppress selected parts |
                            | D |
                            Delete selected parts |
                            | A |
                            Show all parts |
                            | U |
                            Suppress unselected parts |
                            | B |
                            Create new bookmark |
                            | R |
                            Reverse displayed parts |
                            | Control + F1 |
                            Show/hide Hints & tips |
                            | F1 |
                            Show/hide Help panel |
                            | F2 |
                            Show/hide Project tree panel |
                            | F3 |
                            Show/hide Bookmark browser panel |
                            | F4 |
                            Show/hide project comments |
        View
                                | Shortcut |
                                Function |
                                | F |
                                Fit view |
                                | Shift + Drag |
                                Box zoom |
                                | Shift + 1 |
                                Front view |
                                | Shift + 2 |
                                Back view |
                                | Shift + 3 |
                                Left view |
                                | Shift + 4 |
                                Right view |
                                | Shift + 5 |
                                Top view |
                                | Shift + 6 |
                                Bottom view |
                                | Shift + 7 |
                                Isometric view |
            The following views also include
Inspire key
                    mappings:
                                | Shortcut |
                                Function |
                                | Control + F7 |
                                Front view |
                                | Control + Shift + F7 |
                                Back view |
                                | Control + Shift + F8
                                Left view |
                                | Control + F8 |
                                Right view |
                                | Control + F6 |
                                Top view |
                                | Control + Shift + F6 |
                                Bottom view |
                                | Control + F9 |
                                Isometric view |
        Selection
                                | Shortcut |
                                Function |
                                | Control |
                                Multi-select and toggle select |
                                | Control + Drag |
                                        - Drag top-left to bottom-right: select all entities that
                                            are partially enclosed in the box
                                        - Drag from bottom-right to top-left: selects all entities
                                            that are fully enclosed in the box
        Clip Plane
                Note: Activate the clip plane by pressing the
                    (Clip assembly with a plane) icon.
                                | Shortcut |
                                Function |
                                | Control + pick face |
                                Orient the clip plane to the part face |
                                | Control + Left mouse button |
                                Rotate the clip plane |
                                | Shift + Mouse wheel |
                                Move the clip plane up/down - slower |
                                | Control + Mouse wheel |
                                Move the clip plane up/down - faster |
