Altair® Panopticon™
Adding More Data Tables Using the Workbook Internal Data Table Editor Layout
You can add several data tables that you can use to build the different visualizations and parts in the dashboards of a workbook.
1.     On the Data Table pane, click .
The Workbook Internal Data Table Editor view displays.
2.     On the Data Tables pane, click  and select New Data Table:
A new data table is added in the list  and the Workbook Internal Data Table Editor view changes to display the enabled Data Table Settings and Data Sources panel.
3.     Repeat steps 3 to 11 of the Adding a New Data Table section.
