Altair® Panopticon™
Adding a New Data Table using the Workbook Internal Data Table Editor
In the Workbook Data Table Editor, follow the steps below to add data tables.
1.     On the Data Table pane, click  .
The Workbook Internal Data Table Editor view displays.
2.    On the Data Tables pane, click  and select New Data Table:
A new data table instance is created.
In the Connector List pane, some connectors require additional third-party software installation to be enabled. This typically requires adding JAR files to the Libfolder of the Tomcat installation and restarting Tomcat. For the supported Elasticsearch connectors, refer to the Elasticsearch Connectors Dependency Installation section. For the other connectors, refer to Panopticon Real Time Installation and Reference Guide for more information.
3.     On the Data Table Settings pane, enter the Title of the data table and click . The new name is applied to the data table under the Data Tables pane and on the Data Sources pane.
4.     Enter the Description of the data table.
This is also displayed under the data table instance which can be helpful when selecting among the data tables in the list.
5.     You can opt to enter the Auto Refresh period.
This property defines how often the data source is checked for new data, when accessing the source directly. Panopticon will issue new queries at the interval shown in the Auto Refresh (s) box and automatically deliver updates to the workbook. The default is 900 seconds (15 minutes). The minimum refresh period depends on the performance of your data repository and the amount of time required executing your data queries.
If a streaming source is selected, the refresh period is ignored.
   NOTE
·           Setting the Auto Refresh field to any value less than or equal to zero will disable the auto refresh for the data table.
·           The Auto Refresh property is a string and can be parameterized.
6.     You can also opt to enter a custom Error Message that will be displayed when an error occurs while fetching data.
   NOTE
The Error Message can be parameterized.
7.      To add a data source, click a connector group tab.
·        File/URL
Then select one of these data sources:
·        Altair AI Hub
·        Altair IoT Studio
·        Altair IoT Studio Write
·        Azure
·        Google Cloud
·        JSON
·        MS Excel
·        OneDrive
·        S3
·        SVG
·        Text
·        Web Data
·        XML
·        Database
·        Cassandra
·        DolphinDB
·        Elasticsearch 6.x
·        Elasticsearch 7.x
·        Google Analytics
·        InfluxDB
·        JDBC Legacy
·        JDBC
·        Kx kdb+
·        KsqlDB
·        LivySpark
·        MongoDB
·        OneTick
·        OneTick Cloud
·        Panopticon Data Extract
·        Python
·        Rserve
·        Shakti Beta
·        Splunk
·        Streaming
·        ActiveMQ
·        Amazon Kinesis – Data Streams
·        AMPS
·        DolphinDB - Streaming
·        Google Cloud Pub/Sub
·        JDBC Database - Streaming
·        Kafka
·        Kafka Publisher
·        Kdb+ Tick
·        KsqlDB – Streaming
·        MQTT
·        OneTick CEP
·        Panopticon Streams
·        RabbitMQ
·        Redis Streams
·        Solace
·        Streams Simulator
·        Streams Simulator - Extract
·        StreamBase 7.1
·        StreamBase LiveView
·        WebSocket
8.     Tap the Preview Selected Data Source slider to turn it on and display the preview of the selected data source.
9.     Then, you can either click:
·          for static connectors
·          for streaming connectors
The retrieved query/table/sheet/schema is displayed in the Data Sources pane. The system displays the preview data at the bottom of the screen.
Click  to collapse the Data Preview pane.
10.     After adding data sources, you can also:
·         Manage data source properties
·         Define transform settings
·         Retrieve external aggregates
·         Add data table parameters
·         Sort columns
·   Define a join or union all of the data sources
·         Add user defined columns such as:
¨        Auto key
¨        Calculated column
¨        Ranking column
¨        Time bucketing column
¨        Numeric bucketing (Identity, Sign, Manual, Equal Density, and Equal Distance)
¨        Text grouping column
11.     Click the Save  button.
When saved, the notification displays:
12.   Click . You are returned to the Open Workbook in Design Mode, with the new data table added in the Data Table pane drop-down list.
   IMPORTANT
The succeeding sections in this chapter mostly apply to the Workbook Internal Data Table Editor layout.
