Altair® Panopticon™
OHLC Graph Settings
OHLC Graphs also display time-based distributions of price data. For each time slice, they display:
q  Opening Price
q  Highest Price
q  Lowest Price
q  Closing Price
Similar with the Candle Stick Graph, a vertical line defines the range of traded prices across the period. However, in this case, the left notch determines the opening price, and the right notch determines the closing price.
The OHLC graph settings pane is displayed after clicking the Options  button.
Setting
Bar Thickness
Specifies the width in pixels of the OHLC Body.
Tick Length
Specifies the length in pixels of the Open and Close ticks.
Show Coordinates
Determines whether the graph coordinates (i.e., X-Y plots, or Date/Time-Y plots) on mouse over are displayed in the visualization.
Other visualization-specific properties can be set by clicking on the Y-Axis variable drop area and then selecting the Y-Axis tab:
Setting
Independent Y-Axis Scaling
Determines whether to have each visualization Y-axis in a cross tab automatically scaled independent of the others.
