Creating XML Input Data Source
The XML connector allows the retrieval and processing of XML files, either from a disk, a Text, or from a defined URL.
  1. In the New Data Source page, select Input > Xml in the Connector drop-down list.
  2. Select the XML File Source.
  3. Enter the Record XPath (e.g., //myroot/items/item).
  4. Select either the period (.) or comma (,) as the Decimal Separator.
    Prepend 'default:' for the elements falling under default namespace.
  5. Click  to the fetch the schema based on the connection details. Consequently, the list of
    columns with the data type found from inspecting the first ‘n’ rows of the input data source is populated and the Save button is enabled.
  6. You can also opt to load or save a copy of the column definition.
  7. You can also opt to click . A new column entry displays. Enter or select the following properties:
    Property Description
    Name
    XPath
    The XPath of the source schema.
    The data type of the column. Can be a Text, Numeric, or Time.
    Date Format
    Enabled
    Determines whether the message field should be processed.
    To delete a column, check its  or all the column entries, check the topmost , then click .
  8. Click  . The new data source is added in the Data Sources list.
