Zuken Design Gateway
Use the File menu to import and read Zuken Design Gateway ASCII files.
View new features for PollEx 2023.
Discover PollEx functionality with interactive tutorials.
Discover PollEx functionality with comprehensive user guides.
This section contains the user guides for the following tools: Block JIG Generator, Compare GDSII, Gerber to PCB, Make Board Paneling, Metal Mask Manager, Mounting Data Extractor, Mounting Emulator, Router-Machine JIG Generator, Solder Quantity Calculator, Soldering Pallet, Test Point Location Generator, and Underfill.
This section contains the user guides for the following tools: BOM, CAM, Component Arrangement Plan, CP, Golden Sample, Logic, PCB, Redmark+, and Worksheet Planner.
Environment migration is a tool that migrates environment files used in the previous version of PollEx to the latest version.
PollEx BOM is a BOM parsing and formatting tool
Use PollEx CAM to handle any type of Gerber, such as 274D or 274X, convert 274D to 274X type, and compare each revision data.
The Component Arrangement Plan function replaces a paper worksheet with a graphic display report that shows on-board components with their area and marking at first pin.
PollEx Cross Probe (CP) supports two checking types, Same Type Check/Compare and Link and Search.
PollEx Golden Sample generates guide documents automatically.
Use PollEx Logic to import and view schematic sheets, designs, check symbols, nets, and object properties.
Use the File menu to import, export, and print design files.
Use the File menu to import design files.
Use the File menu to import and read EDIF2.0.0 files.
Use the File menu to import and read Zuken System Designer ASCII files.
Use the File menu to import and read Cadence Concept ASCII files.
Use the File menu to import and read Cadence OrCAD ASCII files.
Use the File menu to import and read Mentor DxDesigner ASCII files.
Use the File menu to import and read Altium Designer ASCII files.
Use the File menu to import and read SBD Binary files.
Export a design to an ASCII file.
Use the File explorer to print a design.
Under the Setting menu, there are many settings for defining default value for using PollEx Logic. Use the menus under Setting in main menu.
The Tools menu offers many useful functions to review schematic design.
Use the View menu to set the view.
Redmark is a function to make comments in the design. This function can be used to leave messages or comments to assign tasks.
PollEx suite is a knowledge-based design-verification toolset for PCB.
In Redmark+, it is enabled to get the upgrade features for mark-up tools such as drawing object, text, measurement and reply, history, and so on.
This section contains the user guides for the following tools: PI, SI, SI Explorer, and Thermal.
This section contains the user guides for the following tools: DFA, DFE, DFE+, DFM, and Logic DFE.
This section contains the PollEx UPE user guide.
Instruction to install PollEx 2023.
Definition for meta character using in making sentence for searching option.
