Change Net Name
In case of Zuken Board Designer Interface, it is possible to change the net name of PCB layout from *.ruf file.
It can be changed on PDBB. Only same pin connection will be changed.
View new features for PollEx 2023.
Discover PollEx functionality with interactive tutorials.
Discover PollEx functionality with comprehensive user guides.
This section contains the user guides for the following tools: Block JIG Generator, Compare GDSII, Gerber to PCB, Make Board Paneling, Metal Mask Manager, Mounting Data Extractor, Mounting Emulator, Router-Machine JIG Generator, Solder Quantity Calculator, Soldering Pallet, Test Point Location Generator, and Underfill.
This section contains the user guides for the following tools: BOM, CAM, Component Arrangement Plan, CP, Golden Sample, Logic, PCB, Redmark+, and Worksheet Planner.
Environment migration is a tool that migrates environment files used in the previous version of PollEx to the latest version.
PollEx BOM is a BOM parsing and formatting tool
Use PollEx CAM to handle any type of Gerber, such as 274D or 274X, convert 274D to 274X type, and compare each revision data.
The Component Arrangement Plan function replaces a paper worksheet with a graphic display report that shows on-board components with their area and marking at first pin.
PollEx Cross Probe (CP) supports two checking types, Same Type Check/Compare and Link and Search.
PollEx Golden Sample generates guide documents automatically.
Use PollEx Logic to import and view schematic sheets, designs, check symbols, nets, and object properties.
PollEx suite is a knowledge-based design-verification toolset for PCB.
Explore the PollEx PCB interface.
The PollEx PCB tool bar contains frequently used menus.
View controls enable you to control the view and display of your model in the modeling window.
Use the File menu to check basic functions, import ECAD files into PollEx PCB, and export working design to 3rd party EDA vendor formats.
Import ASCII files from ECAD vendors.
Under the setting menu, there are many settings for defining default value for using PollEx PCB. Use the menus under Setting in main menu.
Use the View menu to control the display more efficiently.
Using Properties menu, you can see and edit properties of objects on board or library link.
Under the Tools menu, there are many useful functions. Almost functions help you to get documents or reports for nets or components.
Use the PCB Explorer to search components or nets.
If the origin point of PCB design is incorrect, you can change its origin point with this function.
Create a worksheet for component placement.
Export PCB information into MS/Excel file
Decoupling capacitor (By-pass capacitor) is capacitor device which connect power and ground nets for the purpose of making stable power supplying.
You can change the color of net(s) to make it easier for exploring PCB design.
PollEx PCB extracts report for all nets’ length on design.
PollEx PCB makes report for net length analyzing feature.
Calculate thermal resistance value of given material by Thermal conductivity.
After importing Gerber data, you can move or mirror the location of it.
You can layer pairs to be displayed at same time.
BOM Changer can be substituted for part name as part name in the BOM file.
You can check the variant file.
Part Viewer is a viewer for part library used in current design.
Real PCB Assembly Viewer connects the PCB design data and 3D UPF library to create 3D PCB shapes and export them as 3D common data like *.stp and *.stl.
Net 2D/3D Viewer is viewer for reviewing routing nets on PCB. For net structure, it shows structure with 2D or 3D mode. It also supports for multiple nets.
Padstack/Via Viewer is viewer for reviewing padstacks or vias used in parts on active design.
Net Topology Viewer is net viewer with showing topology style.
Make property list for components and their pins.
Refer to each individual user guide for the analysis products in the Solver User Guides Section.
Refer to each individual manual for the manufacturing products.
Redmark is a function to make comments in the design. This function can be used to leave messages or comments to assign tasks.
In Redmark+, it is enabled to get the upgrade features for mark-up tools such as drawing object, text, measurement and reply, history, and so on.
This section contains the user guides for the following tools: PI, SI, SI Explorer, and Thermal.
This section contains the user guides for the following tools: DFA, DFE, DFE+, DFM, and Logic DFE.
This section contains the PollEx UPE user guide.
Instruction to install PollEx 2023.
Definition for meta character using in making sentence for searching option.
