PollEx
PollEx
2023
  1. Home
  2. PollEx User Guides
    Discover PollEx functionality with comprehensive user guides.
  3. Verification User Guides
    This section contains the user guides for the following tools: DFA, DFE, DFE+, DFM, and Logic DFE.
  4. DFA
    PollEx DFA is an assembly status checking toolset for PCB design based on 3D package library.
  5. DFA Item
  • What's New
  • Get Started
  • PollEx Tutorials
  • PollEx User Guides
  • PollEx Installation Guide
  • Character String Search Rule
Index
PollEx
2023
PollEx
  • What's New
    View new features for PollEx 2023.
  • Get Started
  • PollEx Tutorials
    Discover PollEx functionality with interactive tutorials.
    • Manufacture User Guides
      This section contains the user guides for the following tools: Block JIG Generator, Compare GDSII, Gerber to PCB, Make Board Paneling, Metal Mask Manager, Mounting Data Extractor, Mounting Emulator, Router-Machine JIG Generator, Solder Quantity Calculator, Soldering Pallet, Test Point Location Generator, and Underfill.
    • Modeler User Guides
      This section contains the user guides for the following tools: BOM, CAM, Component Arrangement Plan, CP, Golden Sample, Logic, PCB, Redmark+, and Worksheet Planner.
    • Solver User Guides
      This section contains the user guides for the following tools: PI, SI, SI Explorer, and Thermal.
    • Verification User Guides
      • DFA
        • Unified Part Libraries Link
          PollEx DFA is an assembly checking toolset based on 3D package part libraries constructed with Unified Part Editor (UPE).
        • Input Setup
        • DFA Item
          • Collision
          • Lead
          • Placement
          • Component
          • Board
        • Result
      • DFE
      • DFE+
        PollEx DFE+ is a fully automated SI analysis tool.
      • DFM
        PollEx DFM is a board level manufacturability checking software.
      • Logic DFE
        PollEx Logic DFE is a toolset that checks electrical validity and standardizing of schematic design.
      • Technical Cleanliness
        PollEx Technical Cleanliness (TC) is an optional module of the PollEx PCB and a reliability analysis tool set for hazardous areas on a PCB design, using its micro particles.
    • UPE User Guides
      This section contains the PollEx UPE user guide.
    Instruction to install PollEx 2023.
    Definition for meta character using in making sentence for searching option.
PollEx
PollEx
2023
  1. Home
  4. DFA
  5. DFA Item
  • What's New
  • Get Started
  • PollEx Tutorials
Index
DFA Item
  • Collision
  • Lead
  • Placement
  • Component
  • Board
