Component Tab
Modify contents of Net Group using component pins.
This method is almost the same as the Component Pin sub-menu in the Classification Tab.
View new features for PollEx 2023.
Discover PollEx functionality with interactive tutorials.
Discover PollEx functionality with comprehensive user guides.
This section contains the user guides for the following tools: Block JIG Generator, Compare GDSII, Gerber to PCB, Make Board Paneling, Metal Mask Manager, Mounting Data Extractor, Mounting Emulator, Router-Machine JIG Generator, Solder Quantity Calculator, Soldering Pallet, Test Point Location Generator, and Underfill.
This section contains the user guides for the following tools: BOM, CAM, Component Arrangement Plan, CP, Golden Sample, Logic, PCB, Redmark+, and Worksheet Planner.
This section contains the user guides for the following tools: PI, SI, SI Explorer, and Thermal.
This section contains the user guides for the following tools: DFA, DFE, DFE+, DFM, and Logic DFE.
PollEx DFA is an assembly status checking toolset for PCB design based on 3D package library.
Group the same type of objects into the same group.
Make components into user-defined groups.
Group certain types of nets/routing patterns to be checked for the same rule.
Make a Net Group using a Binary Database.
Add Group or edit existing net classes.
Review created Net Group and according nets.
Review and modify the Net Group contents throughout the Net Group assigning process.
Generate circuit in the similar method as Net Group Type setup.
Generate via definition and classification which will be used for Ground Coverage, Antenna Ground and Ground wall of via rules checking via location and their area coverage to improve the ground stability in order to reduce EMI noise.
Report passed items in addition to failed items.
Assign points to warnings in various check items differently.
View DFE Environment setting methods.
PollEx DFE+ is a fully automated SI analysis tool.
PollEx DFM is a board level manufacturability checking software.
PollEx Logic DFE is a toolset that checks electrical validity and standardizing of schematic design.
PollEx Technical Cleanliness (TC) is an optional module of the PollEx PCB and a reliability analysis tool set for hazardous areas on a PCB design, using its micro particles.
This section contains the PollEx UPE user guide.
Instruction to install PollEx 2023.
Definition for meta character using in making sentence for searching option.
