Meshed Copper
Check if the bending area is designed with mesh copper.
- Checking
- Item: Specify the item name.
- Check Area: Select layer in which checking area is described.
- Check Layer: Select checking layer on which routing patterns exist.
You can select top, bottom, all, or certain components reverse
side.
Figure 1. - Mesh: Upon checking this option, you can check copper-pour’s meshed status in the checking area. In the bending area, if copper-pour is not meshed, it is fail.
- Thick Pattern: In the bending areas meshed copper-pour, there should be a thick pattern in the middle of the copper-pour. If there is no center line pattern, it is a fail in PollEx DFM.
